Would da Focus CAI fit da Cougar's I4???
Since the Focus also has a Ztec i kind of though some parts would fit a Cougar. M i wrong. I'm trying to get a cold air intake for my cougar. but i could only find short ram intakes. So i was thinking of getting a focus intake instead, n just do some modifications as to make it fit. So your info would much appreciated thnx.
ground pounding..
Re: Would da Focus CAI fit da Cougar's I4???
da fokus cai mite fit, but u need to pm jamallot
www.myspace.com/georgeatchison ![]() [b]UPDATED NECObash INFO 8/5: DATES ARE SET, Win a $350 MasterCard Gift Card-RAFFLE!!!! |
2000 SVT Focus CAI will fit with a battery relocation, otherwise it looks like this...Custom Intake(SVT Focus=i4 cougar)
90 degree spectre pipe (with some form of sealing it to the throttle body since it's slightly loose), 6 inch straight pipe, 3" coupler, aluminum "intake pipe",angle it down under the battery.. MAF adapter pipe connects to the end of that.. MAF should reach you may need to remove a zip tie holding it, then put on the filter.. if you want to go further, you can pipe it forward to the front bumber.. a 90 in place of the filter should get you at a decent angle to start piping. |
#8 (permalink) | |
Wow! I think I'll go with that. Thnx. |
you'll also have to figure out a way to get a pcv breather filter thing on there unless you're going to pipe it back into the intake. I just kept the stock hose and put a small piece of aluminum pipe in it to make it larger.. then bought a push on breather at autozone to put on it.
#10 (permalink) |
ground pounding..
Just get a K&N Drop in! The gains from an intake on a Zetec would be about 1whp lol
