| View Poll Results: What should I blow my money on? | |||
| Nothing, roll with it as is 75,000+ miles and all! |
11 | 42.31% |
| Ford Racing's Short Block |
8 | 30.77% |
| Build up a new focus Zetec engine |
6 | 23.08% |
| Various Aftermarket internals (please list details) |
1 | 3.85% |
| Voters: 26. You may not vote on this poll | |||
#31 (permalink) | |
Re: Fordracing.com short block vs. aftermarket internals
as for choices of pans, your pretty much stuck with a stock pan or custom made.
#32 (permalink) |
I still plan to get the ford focus power engine... it just says which engine would you like to get...
![]() http://www.cardomain.com/my http://www.myspace.com/myspaceokay dogs are no match for my car just my front bumper and hood |
#33 (permalink) |
any non-SVT zetec should be fine. although i would choose the ZX3 engine just cause i always choose the focus when looking for parts. their engine bay seems to be a little closer, design and size wise, to ours then the ZX2
#34 (permalink) |
alright thanks thats what i was wanting to know
#35 (permalink) |
I noticed you have a 97 Contour GL - So do I. I need to fix the engine (#3 Piston has a hole about the size of a nickel) and have a limited budget. This is the normal daily drive. Short block or rebuild? I don't need to modify it beyond stock. Fordracing.com has those in stock for the Focus. Will that work?
Thanks. |
#36 (permalink) | |
out of curiosity, how did you put a whole in a piston with a stock engine?
#37 (permalink) | |
but anyway, fortune would have it that a turbo has fallen into my lap ![]() a T25 DSM off of a mitubishi... ramanufactured and under $100. I don't know to much about it.... other than garrett made it, and it happened to be on 210hp cars so it doesn't flow to much. and does anyone know where to find detailed specs... like a flow graph and what boost am I to expect? It wasn't exactly the turbo I was looking for.... but I couldn't pass up the deal. now the challenge begins... the custom manifold is sure going to be a blast, I'll probably spend more money on the equipment to make it than the mild steel. |
#38 (permalink) | |
You can get compressor maps here, along with a decent calculator. you should be able to search for part numbers online and find out what exactly it is.
#39 (permalink) | |
but, please tell me I made a good choice in buying standard metal cutting bits for the exhaust ... I totally forgot to look *runs out to check* crap.... thats $64 I'll be returning... *edit* again I was under the assumption that america was capable of buying non-fractional bits... so I am going to kind of fix the difference with a file... but is cobalt better than the generic metal bits? is it worth the extra price? was looking at Dewalt in particular.. I have dewalt's DW1969 kind of thinking about the DW1269 the cobalt version of the previous... is $80 more worth it? Last edited by CheeseEater88; 09-20-2008 at 11:17 PM. Reason: Dual unit systems make things hard to deal with |
#40 (permalink) |
Speed Doctor
Well you could always buy some of the prefab pieces that will take some of the headaches. There's a nice manifold by Milltek on pumaspeed that only needs a flange & then you only need to fab up a downpipe.
I was wondering if someone knew how to bead roll or lip the charge piping so it doesn't slip off the couplers? I saw in PCmag they used an old bench rotary tool to do it, but any tools from like harbor freight that would work? |
