Old 05-01-2008, 07:22 PM   #1 (permalink)
JE pistons
will JE pistons work in the Zetec Cougar
J2006 is offline
Old 05-01-2008, 08:28 PM   #2 (permalink)
Re: JE pistons
I have Probe pistons and Eagle h-beam rods for a focus in my contour Zetec. if you are going to use focus pistons you MUST use focus rods as the compression height of the piston is different for the focus than the contour/cougar.
Daniel,
'97 Contour GL"T"
2000 Black SVTC #391
Turbo Zetec 'tour is offline
Old 05-01-2008, 09:39 PM   #3 (permalink)
Re: JE pistons
are the deck hieghts the same
J2006 is offline
Old 05-02-2008, 08:42 AM   #4 (permalink)
Re: JE pistons
everything else is the same, they just lengthend the rods slightly and lower the compression height of the pistons. im not sure why they changed it though.
Daniel,
'97 Contour GL"T"
