#31 (permalink) |
Re: Throttle Response??
Never ported the intake manifold so i can't say, though, tbh i cant see it making any difference. If you want to port anything, port the exhaust.
As for the tb difference, again, i dont know, i can only tell you what i know from my own experience with the one i have. I guess you would have to look into it. |
#33 (permalink) |
The tb goes straight on, its fixed with four philips (cross head) screws. Throttle cable bracket needs modifying just a little and you need to swap the tps over but thats all.
Mine is a 1998 zetec but they are all the same anyway. Standard 55mmtb on left: FCTB 65mm on right: ![]() |
#34 (permalink) |
I'd imagine you'd have to use a reducer coupler? Thats a pretty big size difference.
~2001 Cougar 2.0 MTX~ ~Aussie Headlights ~WeaponR Intake, TruBendz 2.5" Catback ~17" Kobe Kam 5 Wheels, Kumho Tires |
#35 (permalink) |
My stock TB looks different:
![]() I had to buy a Focus Throttle cable to connect to my TB. ![]() If your TB looks like mine get an 03-04 FC TB. If your TB looks like PID_16V's, then get the 00-02 FC TB. Either way I don't see how you would connect the stock air-box to a FC 65mm TB. You probably need an aftermarket air intake and you need a hose coupler that will fit around the FC TB.
99 Black Turbocharged Zetec MTX: 2.5" Trubendz Exhaust, SCT XCalibrator2 PRP The Band I'm in: Townhouse Suite |
