Old 04-23-2008, 03:20 PM   #21 (permalink)
plays guitar alot
Yofavcracka's Avatar
Re: Throttle Response??
I cant believe no ones said it...
get a lightweight crank pulley.
zxtuner.com Its like, 60 bucks plus a belt. Thatll help out alot.
Lightweight flywheel and bolt ons help alot too. (header, exhaust, intake, throttle body and intake manifold)
Originally Posted by c0alition View Post
so am i missing something..? i measured my throttle body and i could have sworn i was 70mm.. and the 65 is an upgrade?
inside diameter
04 Torch Red Mustang. 181hp, 205tq Eibach Prokit, Tokico Shocks/Struts, CAI, UDP, 9mm Red Wires, Intake Manifold Spacer, Lip Spoiler, Steeda short shifter, Mach One Grill, Rear decklid vinyl etc.
Yofavcracka is offline
Old 04-23-2008, 03:31 PM   #22 (permalink)
stock > ghetto
B3NN3TT's Avatar
Images: 54
Originally Posted by Yofavcracka View Post
inside diameter
Yeah, seriously; inside diameter AT THE PLATE. The SVT Duratec throttle body is only 60mm
Andy- Ohio NECO's "Green Guy"
2nd Place - Best Exterior • 2nd Place - Best Mild • CougarFest 07
...skip the chrome unless you have hoes in different area codes.
B3NN3TT is offline
Old 04-23-2008, 10:56 PM   #23 (permalink)
GTownCougar's Avatar
The optimizing is basically something you do yourself. Just takes a little time, and thats something I don't have much of, so I havent done it. Whered you get the TB for 96 James? Also, do throttle body spacers do anything? Prob not since nobody here seems to have done it. I'd imagine they would cause clearance problems with the hood tho
~2001 Cougar 2.0 MTX~
~Aussie Headlights
GTownCougar is offline
Old 04-24-2008, 05:26 PM   #24 (permalink)
james99's Avatar
i got mine off ebay, but the two focus forums i mention earlier usually has them for about $100
james99 is offline
Old 04-24-2008, 08:48 PM   #25 (permalink)
Nice, I'll have to keep my eye out for one. I just can't see spending 300 for something to give better throttle response. Can get headers for less than that.
~Aussie Headlights
Old 04-25-2008, 12:29 AM   #26 (permalink)
formerly buffdaddy
bdiddy's Avatar
Originally Posted by Pid_16V View Post
Tas i said in a previous post, the car is virtually undriveable until you get used to it, the response is so instant.
you have only ever driven your cougar haven't you?
goodbye Tibby, hello r33 Skyline
Nemesis950psi (10:15:51 AM): I really need some thick meat in the back
bdiddy is offline
Old 04-25-2008, 10:45 AM   #27 (permalink)
Pid_16V's Avatar
Why does your mind go blank when the lights go out
www.cougarsgalore.co.uk
Pid_16V is offline
Old 04-25-2008, 06:05 PM   #28 (permalink)
formerly buffdaddy
bdiddy's Avatar
I highly doubt the cougar was almost underivable after a couple small mods
bdiddy is offline
Old 04-25-2008, 06:27 PM   #29 (permalink)
Pid_16V's Avatar
You have obviously never put a 65mm F/C T/B onto a zetec intake. It just makes it so hard to find the biting point. Obviously once you get used to the difference it is very drivable indeed. Oh and btw, the f/c t/b gets you this increased performance by itself, no other mods needed.
Pid_16V is offline
Old 04-26-2008, 05:10 PM   #30 (permalink)
michig54's Avatar
So what your trying to say is that what cbman said is incorrect?:
Upgrading to the FC 65mm TB and porting the intake manifold to match it will definitely improve throttle response.
And that you don't need to port your intake manifold.
Also whats the difference between the 00-02 FC 65mm TB and the 03-04 FC TB. Which involves less modification/other needed parts?
michig54 is offline
