Old 04-17-2008, 07:53 AM   #11 (permalink)
cbman's Avatar
Re: Engine rpm stays at 3k
If you're getting an O2 Sensor Lean Code, it is very likely that you have a vacuum leak or air coming in that's not measured by the MAF.
Does your "CAI" have a connection for the Valve Cover Breather? If not, your PCV air getting pulled into the intake manifold isn't being measured, and that could cause it to run a little lean.
99 Black Turbocharged Zetec MTX: 2.5" Trubendz Exhaust, SCT XCalibrator2 PRP
The Band I'm in: Townhouse Suite
cbman is offline
Old 04-17-2008, 12:53 PM   #12 (permalink)
c0alition's Avatar
I didn't port the valve cover breather back into the intake.. would that do it?
c0alition is offline
Old 04-17-2008, 06:26 PM   #13 (permalink)
cbman's Avatar
It would cause you to run lean during idle, but I don't know if its enough to make you idle at 3K.
You cold try temporarily disconnecting your PCV hose from the intake manifold and put a rubber cap on the barb connection on the intake manifold.
cbman is offline
Old 04-17-2008, 06:28 PM   #14 (permalink)
c0alition's Avatar
It doesn't seem like an idle.. but i guess i don't know how to define idle.. when i rev my engine past 3k, it won't come back down.. it doesn't raise it self to 3k.. it's only when i'm driving down the road.. when it's idling in the morning it's around 2500, but comes down to about 1500.. which is still higher than normal.. but no problem for me
