The Ford Dealer told me I need a new PCV Valve. Is this on the left side of the throttle body when looking in front of the car. My Chilton Manual says you need to remove the catalytic converter. I'm confused?? Can anyone help me out?
Re: PCV Valve
Feel underneath your throttle body. There is a hard line that comes off the bottom of the intake manifold, right at the throat of the throttle body. There is a rubber hose stuck on it, and that rubber hose attaches to the PCV valve on the other end. It sits in a rubber seat between the heads.
Info from B3NN3TT
It's alright, I'm A Doctor
#5 (permalink) | |
Re: PCV Valve
drain the coolant, remove the 3 bolts holding the thermostat housing (has the upper radiator hose and crossover pipe on it) to the head, move it out of the way. using the correct Torx bit socket remove the bolt that holds the PCV pipe to the block. pull the pipe out, the PCV valve should be stuck on the end that was behind the CAT. replace the PCV valve and reinstall everything. some have claimed that you can get to the bolt without removing the thermostat housing but i have never been able to do so. if you can, great, that means you wont have to drain the coolant.
So I dropped my car off this morning to get my pcv valve replaced. Just got a call from the mechanic who tells me that I have NO pcv valve on my car since I installed my air intake on my car. I am very confused?????
Re: PCV Valve
get your car away from that mechanic, quickly. as i stated before, the PCV valve is behind the exhaust manifold in a triangular shaped piece thats bolted to the block.
#8 (permalink) | |
Re: PCV Valve
quoted for the truth
#10 (permalink) | |
Secretary of the Inferior
Re: PCV Valve
