Old 01-02-2008, 06:26 PM   #1 (permalink)
Ryan's Avatar
Question Spark plugs and wires
I need to replace these and I have read the Zetec FAQ thread on what plugs and wires work with this engine but can anyone tell me which brands they have had good luck with.
Ryan is offline
Old 01-02-2008, 08:44 PM   #2 (permalink)
Hardrive's Avatar
Re: Spark plugs and wires
I'm currently using Bosch Platinum +4 and 8mm Bosch wires. No real reason, got a good deal at the time.
Hardrive in teh Myspace
1990 Mustang 5.0sky
1999 Mercury Cougar 2.0 MTX
Hardrive is offline
Old 01-02-2008, 10:49 PM   #3 (permalink)
2C0UGAR00's Avatar
using double plat spark plugs and omni wires and i just replaced them in the last week and so far so good
http://www.cardomain.com/my
http://www.myspace.com/myspaceokay
dogs are no match for my car just my front bumper and hood
2C0UGAR00 is offline
Old 01-03-2008, 12:52 AM   #4 (permalink)
FRPP wires with autolite double plats always worked well for me. im currently running C-F-M wires and motorcraft copper core plugs
Daniel,
'97 Contour GL"T"
2000 Black SVTC #391
Turbo Zetec 'tour is offline
Old 01-03-2008, 12:53 AM   #5 (permalink)
Ryan's Avatar
cool, thanks guys, I'm just debating as to whether I am going to pick up stock motorcraft parts or going aftermarket.
Ryan is offline
Old 01-03-2008, 01:01 AM   #6 (permalink)
I just installed NAPA/Belden wires.
Lifetime warranty to original owner. OEM style with nice boots.
edgewound is offline
Old 01-03-2008, 10:23 AM   #7 (permalink)
Redlineracer12's Avatar
Autolite Double Plats = Original Motorcrafts
The Autolite wires are good in my experience too.
just cheaper
99 Coug V6 MTX Spruce Green
SVT "Heavy" swap finshed!
CSVT #1321/2150 Born on 1/6/00
213.5whp
Redlineracer12 is offline
Old 01-03-2008, 07:47 PM   #8 (permalink)
Josh125XR's Avatar
just cheaper
True. I used the Champion DB Platium Plugs they work good. gap the plugs at .50. I used Bosch plugs running from the MSD Blaster Ignition Coil
I suggest not using The Bosch 4+ Platium plugs cause Ive heard over time they tend to misfire & decrease your car's performance.
*LoneStar Chapter Mod*
02' Honda Civic Si K20A3
04' Honda Civic Ex D17A2
01' Cougar Zetec MTX *SOLD*
Josh125XR is offline
Old 01-07-2008, 01:52 PM   #9 (permalink)
JohnS'01's Avatar
i have the bosh plats 4+ and have had them for bout a year now and they SSUUCCKK!! so if you got the money go denso or NGK and ford racing 9mm wires from ZXtuner.com .................................................. ..............
why buy junk twice when you can spend money on the stuff you'll never use
01' ZETEC MTX GUNMETAL GRAY
JohnS'01 is offline
Old 01-08-2008, 05:53 AM   #10 (permalink)
Zetec-inside's Avatar
I prefer using the original Ford Motorcraft spark plugs.
Mine lasted 67 000km and then bought new ones.
Zetec-inside is offline
