Old 11-06-2006, 11:00 AM   #21 (permalink)
unkmstq's Avatar
Re: zetec vct problems
well i have to get the ecu reprogramed because in the state of arizona if ur poping a CEL u will automatically fail emissions
unkmstq is offline
Old 11-06-2006, 07:12 PM   #22 (permalink)
Hardrive's Avatar
I find that hard to believe. ( ghost voice ) "If you fix it, cel will go away"
Seriously, open the cam sproket a little. Check the tension of the belt. If the tension is failing, car may start and run poor or just keep turning.
Hardrive in teh Myspace
1990 Mustang 5.0sky
1999 Mercury Cougar 2.0 MTX
Hardrive is offline
Old 11-07-2006, 02:31 AM   #23 (permalink)
unkmstq's Avatar
the belt is perfect the tension is great and no it doesnt run at all it wont start..... and yes in the state of Az they plug into your comp and if u have a CEL there computer will fail you I know this i failed emissions this year because i had two bad plugs misfireing
unkmstq is offline
Old 11-07-2006, 02:31 AM   #24 (permalink)
unkmstq's Avatar
Its arizona emissions law
unkmstq is offline
Old 11-07-2006, 05:19 PM   #25 (permalink)
Hardrive's Avatar
Still, it doesn't need reprogramed. Fix it and the reset the pcm.
1990 Mustang 5.0sky
Hardrive is offline
Old 11-10-2006, 11:37 PM   #26 (permalink)
unkmstq's Avatar
To fix it that would involve not doin the VCT delete Did u even read the forum before u opened ur mouth?? Im doin a VCT delete the only way to fix the CEL is to reprogram the ECU
unkmstq is offline
Old 11-11-2006, 05:42 PM   #27 (permalink)
cbman's Avatar
I have the VCT delete kit and I have the VCT disabled in my program, but now I'm getting a CEL code for the cam position sensor. Its not as simple as changing a 1 to a 0, which is all I though I was going to have to do. I did get a response on the SCT forum that explained a method where you keep the VCT enabled and just change the VCT cam angles and some other values.
99 Black Turbocharged Zetec MTX: 2.5" Trubendz Exhaust, SCT XCalibrator2 PRP
The Band I'm in: Townhouse Suite
cbman is offline
Old 11-12-2006, 08:25 AM   #28 (permalink)
Hardrive's Avatar
Lol Fix your car first, then play with the vct delete.
1990 Mustang 5.0sky
Hardrive is offline
Old 11-12-2006, 08:46 PM   #29 (permalink)
unkmstq's Avatar
Yea thats it buy the vct selonoid to fix my car and then delete it do u even see what ur writing or do u blind type
my vct selonoid went bad so im gonna delete the vct and do my timing that will fix the car but intern make the CEL pop like i said did u even read this forum before u typed
unkmstq is offline
Old 11-12-2006, 08:49 PM   #30 (permalink)
unkmstq's Avatar
And that is exactly what im buyin the sct for............but i also am gonna put an adjustable cam gear on that cam and the only way to do that is to delete the vct...............did u buy the sct for ur car??? i talked with another guy that told me he bought an sct and it fixed all that
unkmstq is offline
